I’m sitting here listening to Steve talk about how every browser is just Chromium. 3x is definitely a sus number, but all Chromium browsers are not the same!
Although ironically Brave isn’t benchmarking so well right now. And for what it’s worth Edge has very often been #1 on this list.
And Brave’s speed is based on the built in ad and tracking blocking, so those sub-sites are never called, which, on a heavily enshitified site can make a huge difference. That said, I use DNS blocking, so it doesn’t make much difference on my devices.
Yes but you wouldn’t think those things would factor in on benchmarking pages.
Some pages have so many ads and tracking sites linked to them, that this crud takes 3-5 times longer to load than the page itself and the page doesn’t mark itself as loaded until all that crud has loaded as well, so that would seriously affect the loading times with a browser that, in standard configuration, loads all that crud and Brave, which in its standard configuration blocks all the crud from even being called, let a.
With my Desktop Computer there was another way of getting TPM 2.0 that was not mentioned.
I have a Custom Built Computer with an Asus Workstation Motherboard, a 6th gen Intel i7 CPU & 16GB of Ram. Using 2 nvme Samsung SSD,s
When I found out about the Windows 11 requirements I looked at my Motherboard Manual & found that it had a connection for a TPM 2.0 Module. I ordered the Asus Module on Amazon.
I am on Windows 11 Pro 25H2 & everything is working just fine.
I mentioned this in the Android section. I use Open Source Software whenever I can. So recently I switched to Fossify Open source apps to replace the Google stuff.
They make nice clean easy to use apps. For me they are better than the Google Apps.
I use the Fossify Gallery,Messages,Phone,File Manager,Calendar, & Contacts.
Google can easily look at the Source Code. Google just wants to control everything like Apple does with their iPhone.
I am going to have to look at Graphene OS as I have older Moto cell phones were I could try it out.
