Hi all
I’m trying to find out differences in pc monitors
BUT in a diuretic way
I know
TN VA IPS and the way they work and the way they’ve made
And contrast and color and viewing angels and response time
I need to know about the quality and amateur experience for normal use in standard sizes like 27” or 32”
And brands that offer better on any of these technologies
And which side is better to keep or sacrify if you get a good deal
Or is it worth it to buy one rather than others
And life span and reliability
And dpi and resolution
For example is it important to go for 32” 1440 VA and good ui IO
Or 1080 ips but cheaper on less IO
Or ultra wide 1080 ips over 1440 VA
Thanks
