Supply Corona Data to help?
This seems like a good (easy) idea for healthy people to supply more data for better decisions related to this Corona Virus crisis. https://www.howwefeel.org/
Thoughts?
Install a single purpose app to, in essence, fill out a survey? No thanks.
I’m sure they thought that was the best way to get “reliable” location information, but since the whole premise is “self-reporting” why not allow the people to report their location at their comfort level as well.
I like this approach much better, but it is only for Canadians: https://flatten.ca/heat-map
Do you think it can help in a meaningful way?
Internet surveys are just as likely to give wrong or intentionally bad information as good information.
