I have 2 amazon echo devices i 2 different locations with 2 separate wifi network
And im using home automation devices controlled with voice commands
But my issue is I don’t want the voice command in one triggers the voice on the other device
Is there any ways to have 2 echo device on same alexa app with NO connection
Or should i use 2 amazon account with 2 phones to ensure it doesn’t happen
It’s frustrating
Please help
Unfortunately Amazon doesn’t support multiple homes in their Alexa app, so you can either try to name everything appropriately, use groups etc. to mimimise turning stuff on in the other house, or use two accounts.
Problem with two accounts is Prime if you use any of their services. You dont want to have to subscribe twice.
Thank you yeah that’s unfortunate
I tried to make everything separate by names and groups
My only concern is i dont wanna play music on one and the other one responds or ask something from this one and the other one answers
And also wanna is ensure there is no walkie talkie option so no one can listen to each other through this
