How does “Spaces” (virtual desktops) work on a dual screen Mac? Does each monitor have it’s own set of Spaces, where monitor 1 can have desktop 1 2 3…, and monitor 2 can have desktop 4 5 6… and switch each monitors Spaces independently? Or are both monitors considered 1 desktop and you have Spaces 1 2 3… that can only be switched concurrently?
Let me know how what you decide about a dual monitor KVM and how well it works. I’m in a similar situation (Windows though). I currently have work laptop and my main computer connected to two monitors, using each monitor’s input selection to switch. My mouse and webcam are plugged into my keyboard’s built-in USB hub so I just disconnect my keyboard from machine and connect to the other. It can be a little tiresome doing that.
Work laptop’s VPN cuts the machine off from the rest of the network, otherwise I would have just used remote desktop.
