I purchased 1Password Family and installed on a couple devices. After a few months now determined we like LastPass Family better. Is there a known solution to synchronize any new 1Password records back into LastPass which is still on our other family devices? I’m sure I could export the 1Password records and import back into LastPass but am not aware of any deduplication. Need to merge 1Password with LastPass.
In both directions, it is export and then import.
LastPass support assured me upon import of the 1Password records, I would be offered a prompt to decline overwrite of existing records. This should prevent duplication.
Well, it did not work. Odd thing is, at first I did not see any duplicates using the macOS app but after reinstalling the iOS app, I see all the duplicates.
