I have been a Wasabi user ever since I heard their first ad on SN. Right now I have their Wasabi Explorer for Cloud Storage on my Windows laptop. However, I am migrating to Linux, specifically Ubuntu 20.04. Their app only runs on Windows, and the recommendations I have found so far for a GUI based S3 file utility are lacking.
So, I have decided to try running it under Wine. It installed fine, but launching the app does nothing. Have any of you got Wasabi Explorer for Cloud Storage running under Wine? Or do you have any recommendations? Sadly, it is not a self contained PE, so launching from the command line with debugging has not been an option.
I’ve not used Wasabi, but given that Linux and Windows file systems work totally differently, I wouldn’t be surprised if it didn’t work.
(I’m assuming that Wasabi works by showing local and remote file systems and marking files/folders to transfer/sync? The Quickstart tutorial for the Mac certainly looks like it shows local and remote file structures.)
Edit: take a look at this Linux Today article on integrating it into Ubuntu. You don’t need the explorer.
Edit: It should integrate it directly into the local file structure, so you don’t need the Wasabi Explorer, you just use whatever file browser you usually use under Linux and the Wasabi branch should appear automagically.
