Does anyone know of a USB-C hub that supports USB PD 75W or 100W pass-through charging, and ideally has all of its connectors on the same side, like in the pic?
The one that came with my laptop won’t fast-charge it, so I get the Windows warning that if using the laptop it will still run the battery down.
I’ve tried an Anker PowerExpand+ one, but it won’t sit neatly at the back of the desk like this.
Thanks, both. That Anker looks amazing, but I prob wouldn’t use that many ports. All I use is a couple of USB-A and the USB-C for power pass-through. I have another couple of USB-C and SD on the laptop.
It doesn’t have all connections at the same side but does 100w PD. I have it stuck underneath a laptop riser and switch the single cable between my work laptop and my MacBook Pro. Since it’s hidden underneath I don’t see the cables so much.
