On that refrigerator filter thing.
They are just on a timer. My fridge filter goes “bad” every 6 months exactly.
You can just reset the alarm usually by holding one of the buttons for 3 seconds.
In my old fridge, I had removed the filter completely, yet “somehow” it would still “expire” every 6 months.
It’s 10000% a scam.
I use a filter for two cycles. I’ll just reset it when it yells to.
Na, the chemical symbol for sodium, comes from the Latin Natrium. So the inspiration for the naming “TerraPower’s Natrium technology” is clear.
