That’s exactly the point. I think there are poorly designed WiFi Access Points that want to hand off the device from the 2.4GHz network to the 5GHz network, and of course that’s never going to work. It’s probably the case that the WiFi implementation in the cheaply built IoT device inadvertently “lies” about its capabilities and makes the AP believe it could be redirected when it should not.
