Rosemary, you can use Home Assistant as you mentioned (giving your parents access but not to the cameras) depending on how you setup your cameras… I have my cameras on a separate “tab” or “page” in Home Assistant and you can grant user’s access to or remove user’s access to specific tabs/pages. But you can’t just hide the Home Assistant Card that exposes the cameras, at least not yet… but aren’t you a developer? you could make that happen! wink wink!
Cheers,
Chris
