I keep getting a error message that says “Incorrect QR code, try again” when I try to signup or login with SQRL.
What has happened to @josecgomez? He’s the author of the code that is on sqrloauth and so far as I know it’s not open source, so only he can fix it…? Right now it seems like abandonware…
So sorry didn’t notice it was down. Had some server issues a few weeks ago and I guess it went down
I’ll get it spun back up in the morning
Looks like an expired password
I’ll also get some monitoring on it
Apologies for the delay this has been restored now. Let me know if you run into any issues.
The signup still doesn’t work… I don’t think it has worked in many months. Any plans to investigate?
Sure thing I’ll take a look didn’t know it was broken,
I consistently get “HTTP Response Code: (500) unsupported Try Again” when trying to register SQRL with twit.community profile.
I think the SQRL server by @josecgomez has been down for a while. It’s required for SQRL registration here. Perhaps he’ll respond?
Hmm server is up I’ll see if I can find out what’s up
Issues have been resolved and SQRL Auth is fully back up and running sorry about that. Honestly I just thought nobody was using it and quit checking on it. (It is mostly self run, but there was an API that I was using (3rd Party) and that has gone offline which caused the initial issue)
Were your ears burning? We talked about you and the auth server on Security Now last Tuesday! Thanks for all you do!!
