Regarding IE on supported platforms, those would be Windows Server 2012, 2016, 2019 and 2022.
Also the IE 9.02 and Office, I assume they closed the hole in IE, because it was an internet browser, but Office was left vulnerable, because it was internal and the feature useful.
As Steve said, it should have been closed at the same time.
You talked about Google introducing DUNS validation for Google Play, just wanted to add that this is the way it already (allways?) works on the App Store, so most developers will already have their DUNS number registered, if they develop apps for both platforms
On the Apple side, you need a DUNS number as a corporate customer as well. We wanted to set up MDM and to use the Apple push and corporate store infrastructure, you need to register with your DUNS number.
