https://twit.tv/shows/security-now/episodes/800-0
The download file seems to be corrupted. Can’t access on my android phone with Podcast addict and download links are broken as well.
***EDIT: OK my (kind of) fault. It looks like Chartable chtbl.com was added to a DNSBL I use on my pfsense router to block ads and tracking. I put in a rule to allow and all is good.
What is going on? I can’t stream nor download my twit podcast! Tried with 3 different podcast apps on Android.
Which podcast? Is it possible it’s one of the ones that has ended its run? If not, then is your configuration set up with some sort of DNS blocklist… are you blocking Chartable (I think it was recently added to some blocklist somewhere.)
