any free recommended easy tools to used to replicate/duplicate usb drives ?
It’s unclear why you need a special tool? Plug both drives into the system, open the source drive in Windows Explorer, press CTRL-A to select all files, CTRL-C to copy them, then open the destination device in Windows Explorer and press CTRL-V to paste all the files, and then wait for the copy to finish.
Or Windows provides RoboCopy if you’re willing to work on the command line.
its a bootable drive that’s why
Okay, have you tried using Win32DiskImager or Rufus or BelanaEtcher? https://alternativeto.net/software/win32-disk-imager/
usbimager for the win ! thanks for the link again
