I everyone in TWiT land, two questions…
What is the best program to clone a hard drive for windows 10?
What is the best free password cracking program for windows 10, Ophcrack does not seem to work anymore…
I haven’t had to image a physical PC in a while, but I used to use Acronis True Image for one-off situations.
For the password cracking take a look at Passcape’s Password Recovery Software - Password Recovery Software (passcape.com)
You need an optical drive and are sill Bois based, but I remand Clonezilla.
I don’t remand any password cracking program since I find them all computer viruses.
The Security Now guy, Steve Gibson, recommends Image for Windows - TeraByte Unlimited which is not free, but supports about as many options as you’d ever need.
Doesn’t Windows 10 have a built in system imaging tool?
I don’t think Windows 10 or 11 has built in imaging tools.
I don’t know I would trust it, I want to boot wt a usb thumb drive and clone the HD that way…
Windows 10 does. You can create a system image.
You are using Windows 10 but you don’t trust it? What?
What ever you do don’t Google to find out.
I have used https://alternativeto.net/ its been some help… I miss Norton Ghost.
I have used Macrium Reflect.
What Windows has built-in is pure backup (which you should be doing anyway), but I grown to like the features 3rd party tools have better anyway.
I have settled on rescurezilla, it is most like Norton ghost.
Most virus scanners will pick these up as a hacking tool or a potentially unwanted program rather than an actual virus (although some of them might have some malware attached to them depending where you download it from)
