After listening to this week’s tech guy I thought I would ask this question regarding MoCA.
A few summers ago I wanted to hard wire all my Orbi (RBK40 system) satellites together using MoCA. I got 4 HiTron 2.5 MoCA adapters.
I live in a single family home and the cable from the pole is split 2 ways, one goes to the basement (which eventually makes its way to the family room connected to the cable modem) and the other split goes to the bedroom that connects to the VOIP modem.
Nothing else goes through the cable anymore but internet. It took me a little manipulating but eventually I got all the MoCAs to connect and the ORBI was reporting all 3 satellites were connected via wire.
Now, as time went on, from time to time, (I think) the MoCA in my bedroom would lose connection to the one at the router. This would cause the entire network to become unresponsive until the connections to all satellites were re-established. I really thought this was strange since it was only the 1 MoCA/Satellite that lost connection, but it would take the entire network down.
Also, in my basement I have a bunch of Retro Computers (Atari 8/16 Bit) set up, and I use an ESP232 based wifi modem with those.
For some reason when I would be using the ESP232 wifi modem, it would get extremely choppy. i.e. I would be typing a message and as I was typing it would pause for say 1-2 seconds and then catch back up. It would do this constantly. Thought I was the EsP232 modem, talked with the creators and we could never figure out what was the issue.
Well after a few times of the MoCA taking the network down while my wife was trying to watch Netflix, I decided to give up on the MoCA. I ended up returning two of the units but still have 2.
Once the MoCA’s were out of the loop my Retro Computer Modems started working properly. So that issue was caused 100% by the MoCA.
I eventually pulled cat 5/6 cable for the family room and Living room. Those two satellites are no hard wired to the router.
My bedroom is still connected wirelessly. Hearing it discussed on the show, spurred me to look into connecting the remaining mocas I have and see if I could get it to work any better.
There was a filter spoken about. I don’t/Didn’t have this installed, but it seemed to me as explained on the show this was more geared for an apt building where the cable is shared across many units. Could this help with my original issue? Let me know if I am wrong on this.
Does anyone know why the MoCA’s would cause the entire network to go down while they are reconnecting? I am probably going to give the bedroom to the router another try.
Any insight appreciated.
