I bought the new MacBook Pro 16 inch with the M1 Pro. Before that I had the 2016 model and have always had the Belkin USB-C to LAN adapter. Does it still work with the new M1 because the Apple site does not advertise the adapter for the 2021 MacBooks?
So you actually [still] have this adapter? What’s stopping you from just trying it? USB is standardized, so the worst that would happen is basically nothing. (i.e. if it needs a driver it doesn’t have, it will not work.)
@Martini89 I’d say you are worrying unnecessarily. I’ve bought a couple USB C dongles/docks. The first one I bought cheap when I purchased the mac simply so I could do HDMI hook up on my 2019 Macbook Pro and also give myself on USB A port. I later bought a dongle that had HDMI, LAN, SD Card, and 3 USB A ports. Still own both of these, but once I found a dock that actually sits under my macbook that is the one I settled on. Plugs in via USB-C but since it only slightly raises the profile of my mac which is already on a stand anyways it has been my preferred docking solution.
