For me no cell phone is worth $1200.00. For a lot of people this is not an issue because they don’t mind paying for High Cell Phone Plans to get a Free Phone. it all comes down to your needs.
I know a friend who paid $1000 bucks for a high end Samsung, & now he is stuck with Android 8.
I recently got a new phone myself. it does everything I need to do & does it well. It came with a Fast Charge Kit for the Car & a Clear case.
Here are the specs…
200 g (7.05 oz)
Glass front, plastic back, plastic frame
SIM (Nano-SIM) Hybrid Dual SIM (Nano-SIM, dual stand-by)
Water-repellent design
Display IPS LCD, 90Hz
Size 6.5 inches,|
720 x 1600 pixels, 20:9 ratio (~269 ppi density)|
Platform OS Android 11
Chipset Qualcomm SM6115 Snapdragon 662 (11 nm)|
CPU Octa-core (4x2.0 GHz Kryo 260 Gold & 4x1.8 GHz Kryo 260 Silver)
GPU Adreno 610
Memory Card slot microSDXC (uses shared SIM slot)|
Internal 128GB Storage 6GB RAM
Main Camera Quad 64 MP, f/1.7, 26mm (wide), 1/1.97", 0.7µm, PDAF
8 MP, f/2.2, 118˚ (ultrawide), 1/4.0", 1.12µm
2 MP, f/2.4, (macro)
2 MP, f/2.4, (depth)|
Features LED flash, HDR, panorama
Video1080p@30/60fps
Selfie camera 13 MP, f/2.2, (wide), 1/3.1", 1.12µm|
Features HDR
Video1080p@30fps|
Comms WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth 5.0 A2DP, LE
GPS Yes, with A-GPS, GLONASS, GALILEO
NFC Yes (market/region dependent
Radio FM radio, RDS, recording
USB Type-C 2.0, USB On-The-Go
Features Sensors Fingerprint (rear-mounted), accelerometer, gyro, proximity
Battery Type Li-Po 5000 mAh, non-removable
Fast Charging 15W/20W
Anybody want to guess what I payed for this More Bang for your
buck Cell Phone??? If your thinking $1500.00 you’d be wrong.
This Phone has better specs than the iPhone in certain areas, except for the Screen of course.
$213.00 at Amazon. Just call me be the Myth Buster.
I will be getting android 12 as well. My old phone on Android 8 with a replaceable battery is now my backup phone.
