The Tech Guy Labs page for this episode: Episode 1832 | The Tech Guy
Just a couple of suggestions I would have also asked about or tried in relation to the “invalid email” problem.
Sometimes there are password managers or browser extensions that will autofill passwords. I have had blank spaces that I didn’t know where there in password and email fields (if they are at the end then they are often nearly undetectable). While the guy did say he was using different computers and different browsers, if he has a password manager on all browsers then the same sites would always fail on all computers and browsers.
There are also extensions and password managers that will auto send the completed info which has happened to me when I had the wrong email address stored in the manager. That could be why he would get a couple characters typed and it would just send. Essentially as soon as the page loads, the extension attempts the fill and send but it isn’t instant so he may get a few characters typed and the send command is already being processed.
2a. To test would be as simple as disabling the password manager and trying the sites. If it is the culprit then just checking the stored passwords for spaces and/or unchecking auto login.
3a. If that does solve the problem then he could turn each on back on to test which is the problem.
I also would have said to use someone else’s computer other than his own. He say his girlfriend tried hers in his systems but has he tried his on her systems. Maybe try the local library or even just a machine a work that he’s never used before (just to test Leo’s theory about a possible issue being the email address or website itself).
Similar to the password manager or browser extensions would be cloud stored password managers like Google or icloud (or w/e apple might use). Those also can also Auto complete and may be even less noticable because it’s not an obvious extension. As long as you are logged in it just works (if enabled).
5a. You can turn off auto complete for Google passwords in the advanced menu - autofill settings.
With so many browsers storing user profiles in the cloud for seamless cross platform utilization, it is so easy for a user to have some customization that they have set up on one system carry over to all the other systems they use that could easily be the culprit.
Or the issue could be none of these. This was just something that happened to me that seemed really similar and this is what fixed my problem.
