I was looking around at different free VPN services, mostly so when I need to upload photos (batches typically over 1GB/day), I can do so at speeds faster than the 0.7-1.3Mb/s that I currently have (lack of options). I came across a PCMag post for 2020 that listed ProtonVPN as the only free VPN that allows you to to have unlimited data. I’m looking into free because I don’t need it that often, but when I do, it would be nice to get the uploads finished quicker, but I can suffer through if need be. lol
Has anyone here had any experience with them? What are your thoughts?
Not exactly so. My work laptop gets nearly 7x the upload speed when connected to the work VPN. Of course that’s work, so I cannot use it for personal things.
A VPN reduces throughput, because there are protocol overheads. You will never achieve the same speed as a raw transfer. Unless you ISP is throttling certain types of traffic.
If you are getting 7x the speed through the work VPN, there is a serious problem with your Internet connection.
My upload speeds are more than what is advertised with my internet, so I think they are just fine. (It’s not much of a connection anyway with only up to 1Mb/s advertised upload speeds. I’m getting around 1.2Mb/s on average. VPN puts me at over 7.)
My main question here stands…I’m looking for feedback on ProtonVPN free version.
Also keep in mind that your internet connection is only part of the equation. The other part is the server you are connecting to and how it is configured. It may throttle uploads to reduce IO to storage which could impact overall site performance. Or just limit uploads to ensure there is enough bandwidth for other users.
This is like saying you’re looking for new laws of physics. Since the VPN operates over the same wires as you’re already using when there is no VPN, and since the VPN adds overhead to do its thing, there is no way a VPN can make anything go faster… it can only slow you down. If you’re finding it seems faster, it might be that your ISP is shaping your traffic, and when you use a VPN the traffic shaping is defeated because it can’t see what kind of traffic it is, so it can’t apply any shaping. If that is indeed the case, then you have a horrible ISP and you should consider paying for quality a VPN full time. (On the assumption that getting a new ISP is not an option.)
