One thing I miss from Windows is per app volume control. I have found BackgroundMusic, but seems to be very early. There are also a couple paid applications that do what I want. I’m wondering if anyone is using anything that does per application volume control that they can recommend. Needs to work on Big Sur and M1.
It’s not free but Rogue Amoeba’s SoundSource should do what you want
I second that. I need different inputs and outputs for different apps and find this works great.
Thanks, will take a look at that.
Here is another option
Big Sur not supported yet for that one. A whole lot cheaper than the other option though
