so my old iPhone car charger (have no idea how old it is) is not charging my new iphone 14 pro, fast enough. I need recommendations of one that plugs into the cigarette lighter that fast charges it. Is there such a device ?
Thx Twit fam
Thx Twit fam
I use the Spigen Magsafe car charger. No idea whether it is fast charging, but it usually charges from 80% to 95% on the run to the supermarket at the weekend. The limiting factor is the 12V port in the car.
Spigen do various versions for Tesla and Ford F150, for example, but I have an old Nissan, so I bought the universal fitting for the air vent.
Wireless will be slower though. If you’re after fast charging, I’d use a 20W charger. I use Anker. They actually do a 67W one for not much more money if you want to future proof or charge laptops.
Edit - checked mine yesterday, it’s a 50W one, been reliable with no issues.
thank you for this. I will certainly check this out.
thank you for this. I will look into this
