Does anyone know why an LG Nexus 5 keeps appearing on my Google devices? Don’t think my account has been compromised (changed password, 2FA is on). If I look up the IP address the org is my mobile phone provider.
Bit of googling suggests this is linked to using Firefox on your Android phone?? If you use Firefox on your mobile do you see the same on https://myaccount.google.com/device-activity?
If you click on the phone from that device activity page and sign out of it you will soon find out if one if your devices stops working with google services. If it turns out to be something that you use you can always sign back in again.
You could also go into find lost device and find out where its location is to see if that helps you any.
Looks like Firefox mobile is intentionally anonymizing the user agent for a miniscule amount of enhanced privacy when you directly log into Google via Firefox mobile. It has the unfortunate side effect of creating security worries for those who properly pay attention to the security of their Google account.
Maybe. There’s a ‘privacy.resistFingerprinting’ setting in about:config that people say stops Firefox giving an accurate user agent, but it’s set to false on mine anyway. Perhaps I’ll just force the phone model bit.
Read somewhere that Google were doing away with user agent anyway?
