Question: Is Mixer’s chat channel locked to viewers of level 50 or more on purpose? If so, why?|
Suggestion: Instead of streaming without break 24/7 on Mixer, end and start the next stream between each show, update the name of the stream with the recorded show.
- This will make alerts when you ‘start’ your stream, and make it easier to tell which show is being streamed when. Because they’re on a loop, I’ve found it difficult to find and watch the shows I want, since I have to check back regularly, and sometimes miss the start of one because there aren’t any notifications.
