Anybody else getting frequent freezing (daily) with the latest Monterey patch?
Keep finding my MBP frozen when I go to wake it up. Back-light on, caps lock key works but won’t respond.
Usage and apps haven’t changed
Not experienced it on my mini.
Do you have any specific software open when it crashes? Try closing apps before putting it to sleep, to see if it is a specific combination.
I always have the same apps open all the time (Mail, messaging + Twitter clients, Chrome). It’s just that it starting happening after I installed 12.1 on Monday. Maybe coincidental. Could be a Chrome/another app update snuck in I guess.
Next time it happens I’ll see if I can remote in.
It could be that Chrome, for example, needs an update, because it does something naughty that is now caught by the OS update (or the Twitter clients).
No issues on my MBPro or MBAir
It’s just done it while I was using it. Reading a few Tweets, and the screen goes blank. I’m now using it remoted in from another Mac - so it’s still working apart from the display
A reboot fixes it. So unlikely to be a dodgy connector, although it’s had work done on it recently.
I’m using Monterey on an M1 MacBook Pro right now without any of those issues.
There is however a problem with memory leaks on Monterey. Open the Activity Monitor, click the Memory tab, and check to see if anything is using more than a few gigabytes of RAM - if so force close it and see if that fixes the hesitation.
Thanks all. I suspect as @big_D suggested, one of my apps is tripping over something in the latest Monterey patch. I had a fan control app running, for example, so have removed that. TweetDeck is always a bit buggy too.
Did you see people are saying the Monterey memory leak is linked to using non-standard mouse pointers?
Yes, @Leo and the team covered it in MBW a couple of weeks back, I think on TWiT as well.
Dunno how I missed that.
All sorted. Interestingly it was also mouse-related I think. I had the Logi mouse software installed. Removed that and it hasn’t frozen since.
Interesting, I have. Logitech MX Master 2S and the Logi software installed on my mini and I haven’t had any problems so far… Do you have the latest version installed?
Yep, it was the latest version. Could be a corrupted install of course, but I haven’t bothered to reinstall it yet. My custom buttons still work - I guess the config is retained by the mouse once configured. I’m Intel too, not M1.
Okay, I’m M1, so that is another difference.
Apple trying to push you to upgrade.
