How do you get the “licensed” badge?
The description says: This badge is granted upon successful completion of the interactive advanced user tutorial. You’ve mastered the advanced tools of discussion — and now you’re fully licensed!
However - I can’t find that tutorial in the community. And, if you go to the site that runs the software for this forum - the profile created here on the TWIT forum does not exist, You have to make an entirely new profile/screen name…
" Badges? We don’t need no stinkin’ badges!"
Never mind - I figured it out thru google You have to send a message to discobot and then follow his instructions in each following message…
I’ll give that a try after the F1
I just tried to get discobot to run the advanced tutorial, but I’m not getting the syntax right.
Make the message to: @discobot
Then, in the message, write:
“@discobot start advanced tutorial”
Then, he will write you messages with directions. You do what he says, and then he will send you another message right afterwards
Hi! To find out what I can do, say @discobot display help.
Aha, so without the curly brackets then. Thanks.
Yes - I tried that too. When it did not work, I took them off.
I think they did that so the bot isn’t activated. As you can see - he responded just from what I typed, even with the parenthesis around my text (above)
