Help with PAS speed matching between a Lectric Bike 3.0 and a Trike
We love our e-bikes. I have a Lectric 3.0 and my wife has a Lectric Trike. When we are out for a ride it is difficult to match our speeds when we peddle. The PAS (Peddle assist) for each of the levels 1-5 don’t match up between the two bikes. If I want to just use the throttle, I can match her speed but if I start peddling at all, I’m flying by her.
It would be great to be able to adjust the speed within a given level; PAS level 1 wants to fly at 13mph.
Does anyone know how to modify the Lectric’s PAS speed level. It would be great to be able to /root it, but I also don’t want to make a brick.
Can’t see anything to change the speeds, but looks like there are some settings to decrease or increase the number of power levels.
Maybe if you have 6 or 9 power levels, it will give you smaller steps and you can match the assistance better between the bikes.
Note it does say ‘should not be changed unless advised by authorized rep’.
Trying to understand the problem - is the trike heavier, so that’s why it is slower even though the motors are the same power?
Edit, found this. Looks like the rep needs to unlock the 6 or 9 levels.
Lectric XP Programming and Function Complete Guide | Electric Bike Forums (electricbikereview.com)
