hello. leo, i have been a fan since you first appeared on cable! you and (can’t remember his name) did photoshop tips and everything. then the network changed a couple of times ha! i think it became the weather channel now (
anyway, i need to store data on an external harddrive. it needs to be backed-up so i was thinking just a simple disk mirroring. 8TB would be fine, possibly even 4TB. its to store scripts, materials, bitmaps, customization settings and renders and video/animation renders and files. so maybe 8TB?
anyway, i have two network cards in my windows 10 enterprise PC right now. I was thinking it’d be great to have something i could plug into one of the network cards and map it as a storage drive like X: drive.
it’s for work and it’s long term! so i’d like to shy away from best-buy over the counter stuff. but that’s a gray line - i guess i’m saying i need back-up and i need something that won’t fail.
i’ve seen a lot of photographers/video editors use laCie devices, there’s one that catches my eye: LaCie 2Big Raid but that’s USB only i think.
any other suggestions?
