thank you so much for sharing…it was beautful
A related article from Ars Technica:
true, but it can help reduce the chances of transmitting to someone else.
people need to stop thinking “what risk do other people pose to me?” and thinking"What risk to other people do I pose?"
People are lazy and want 1 solution they can invest in, but all of it is required, social distancing, cleaning and masks.
Arguments over which is the best are pointless, when “all of it” is best.
It looks like US is up to its usual dirty tricks in the background.
I am not going to post a specific link, but go search for “US diverts masks from Germany”.
Seems on the 1 hand incoming medical resources are gratefully received, but USA isn’t going to be helping others in return.
3M have been warned that if they allow any of the masks to go to other countries, the Gov will make things go bad for them.
Thats nice. The 3M factory is in China using Chinese labour, products and resources, but they won’t be allowed to keep any there.
That search criteria also yields stories about same happening to Canada and France.
I would argue, if everyone wore a mask, that would have a positive affect from contagious asymptomatic individuals.
" From epidemiologic research, persons living in places where telecommunication masts are erected are vulnerable to disorders like cancer, lung diseases, sleep disturbances and even physical disabilities; though according to WHO research, there are no current scientific proofs of health hazards associated with telecommunication masts."
Reference Link
Here are some organizations where you can help! Whether you are a developer, a maker, organizer, or just want to polish up your rusty sewing skillz, here is a list of organizations organizing volunteers to help:
Astro Print
Maker vs. Virus
Get US PPE
Project N95
Mask-Match
Make the Masks (https://www.makethemasks.com)
Masks for Docs (https://masksfordocs.com/)
Make Masks (https://www.makemasks2020.org/volunteer)
I have been using this slack channel for Masks For Docs: https://slack-invite.masksfordocs.com/
Mask video: https://youtu.be/zm_NmpdgWWA
Filter Material: https://www.homedepot.com/p/RIDGID-OSHA-Compatible-Kit-with-HEPA-Level-Filtration-and-Cyclonic-Dust-Bags-for-Select-12-16-Gal-RIDGID-Wet-Dry-Shop-Vacuums-VF6500/304736564
Cap necessary for us hair follicly challenged. Keeps rope from sliding off.
Talking about shields… the nearest large supermarket to here (a Woolworths) as out large Perspex shields at each checkout to shield the checkout worker. Unfortunately, they could not hear what I was saying so ended up talking around the shield.
I presume that is what I would call plexiglass. Last month two of the major grocery retailers here said they would be installing them as well. I haven’t been out to a store since early March, so I can’t comment on their actual existence.
Yep, Perspex = Plexiglass = clear acrylic
@P_J Sure hides the turkey neck like mine does
What are those tucks-or-slits on each side? Let you breathe under water?
LOL…I’m not a seamster(?) so I doubt if I’ll use the right terminology. It is two layers thick. On the back side, there is a slot/pocket to add additional filtering. I was able to put an N95 inside it but then it was impossible to breath.
Interesting look at “the fundamental interconnectedness of everything” (apollogies to D.Adams)
The “four Horsemen” of overpopulation, globalization, hyperconnectivity and increasingly limited and centralized supply chains are the broad parameters underlying the probability space of catastrophe.
Credit link provided by @Dr.Flay
SUGGEST EVERYONE GET RIGHT WITH THE LORD
WRT masks:
