Hi all,
I am looking for an alternatives to SABRENT USB 3.0 4 Bay 2.5" Hard Drive/SSD.
To connect to my Asus RT-AC86U-91C0 router’s USB port. As for the Sabrent when it is connect only 1 drive is accessible all the other show as unmounted.
Hi all,
The best solution for supporting multiple drives for storage on a network is typically a NAS. The unfortunate thing is that quality NASes are not inexpensive. I would recommend a SynologyNAS, and if you want one for 2.5" drives only, then the 620Slim would work. The downside is the cost (without drives) is around $450US.
Thank You for your reply
