Every time I open Chrome, I see that Flash is going away in Dec 2020.
What comes next? I use the Arlo camera website, and a couple of other website. I assume they will have to update their website some kinda way to work without flash. I have to allow flash on those sites in order to make use of them…
Ah, Flash… the software people love to hate from the software company people love to hate. It’s not like they didn’t earn their reputation by repeatedly having security vulnerabilities for a decade or more now.
Flash is basically a scripting tool and a set of codecs. It’s necessary for your cameras because they output video to a codec that Flash supports (and possibly one that is not well supported by HTML 5.)
The answer would be for Netgear to rewrite their website, and possibly also their camera firmware, so that everything worked in HTML 5 without Flash. This, of course, will cost significant money for them. They’d probably rather just declare those affected products as legacy and leave support of them up to the end user. They would hope you won’t be so pissed off as to not re-buy from them in the future. (This is akin to the issues with Sonos declaring their older products unsupported.)
It’s mostly on websites that have an legal issue on copyright gourds; but is also updated every few hours PD Movies and TV shows. So it’s an HTML 5 site and it even tells you that; but on matter what Webower or OS I use i always what’s me to install flash and even the site’s owner I heard what’s the pop-ups to stop.
ANY SITE that is giving you any indication that you should use or install Flash is serving you malware. You should stop going there immediately. I would not recommend you click on one of this pop-up messages, but if you did, you would most definitely not end up on an Adobe site. No reputable site is still using Flash because it is no longer available.
As a side note: Most users of most forum based sites get a little ticked when you bring an old (2 years old in this case) thread back from the dead. They refer to this as “necro-ing” the thread. The main reason it upsets people is because all the participants usually get a notice about the thread update, and it’s something they thought was long in the past. Based on this, if you’re going to do it, please make sure what you’re adding is actually contributing value to the old discussion.
