Hey
I’m trying to setup Wyze cam 3
I all ready installed Rtsp on Wyze cam 3
I have Synology DiskStation
I just installed Surveillance Station
But when I try to connect the Wyze cam 3 it can’t connect
I have NordVPN setup on my Linksys router
Do I need to setup port for the Wyze cam 3 to work
Any help be great help
Last I checked, Wyze decided to end support for RTSP on Wyze Cam v3. That could be causing your issues with getting it to work.
So
What cam should I buy to be able to use Rtsp to keep the recording on my nas server computer
Does your NAS software not have a recommended/supported camera list? Certainly Synology had one when I last looked (granted that was probably a decade ago, and I never actually acquired one.)
Maybe check out Reddit with some Googling? Such as:
https://old.reddit.com/r/homeautomation/comments/pkdqqc/best_ip_camera_for_outdoor_with_httprtsponvif/
Most IP cameras support RTSP, but I’d go with the suggestion of checking for a compatibility list with your software.
