VMware vCenter TLS Cert auto renew
I’m trying to automate the process of creating and renewing TLS certificates for my VMware vCenter servers using Certify the Web and PowerShell. Certify the Web is a program that runs on a Windows desktop and can generate certificates from Let’s Encrypt or other providers. I want to use PowerShell to push the certificates to the vCenter servers after they are created or renewed by Certify the Web. Does anyone have any experience or tips on how to do this? Here is what I have so far:
# Parameter from Certify the Web.
param($result) # Required to access the $result parameter
#Loads all Module(s)
Try { Import-Module -Name VMware.PowerCLI -ErrorAction Stop }
Catch { Write-Host "Unable to load VMware.PowerCLI module, Please, run 'Install-Module -Name VMware.PowerCLI -AllowClobber -Force'" -ForegroundColor Red; Exit }
#Try { Set-PowerCLIConfiguration -InvalidCertificateAction Warn -Scope Session,User,AllUsers }
#Catch { Write-Host "Self-signed or invalid cert run, 'Set-PowerCLIConfiguration Warn -Scope Session,User,AllUsers'" -ForegroundColor Red; Exit }
#Try { Set-PowerCLIConfiguration -Scope Session,User,AllUsers -ParticipateInCeip $false }
#Catch { Write-Host ", 'Set-PowerCLIConfiguration -Scope Session,User,AllUsers -ParticipateInCeip $false'" -ForegroundColor Red; Exit }
if ($result.IsSuccess) {
    # Edit Variables Below
    $FQDM               = "vcenter.vmware.com" # E.G. vcenter.vmware.com
    $vCenterUsername    = "username"
    $vCenterPassword    = "Your_Password"
    # Do Not Edit Below This Point
    # Setup to connect to a VMware vCenter.
    $vCenterConnection = Connect-VIServer -Server $FQDM -User $vCenterUsername -Password $vCenterPassword
    # Connect to a VMware vCenter
    $vCenterConnection
    # Getting new certs
    $certificatePem = Get-Content -Path "C:\CTW\FullChain\$($FQDM)\$($FQDM).pem" -Raw
    $certificatePrivKeyPem = Get-Content -Path "C:\CTW\FullChain\$($FQDM)\$($FQDM).privkey.pem" -Raw
    # You will need manualy push up CA cert(s)
    # Update the vCenter certificate
    Try { Set-VIMachineCertificate -PemCertificate $certificatePem -PemKey $certificatePrivKeyPem -ErrorAction Stop }
    Catch { Write-Host "Failed to update vCenter certificate. Error: $_" -ForegroundColor Red }
    # Cleans up TLS certs.
    Get-VITrustedCertificate | Where-Object { $_.NotValidAfter -lt (Get-Date) } | Remove-VITrustedCertificate
    # Disconnect from vCenter
    Disconnect-VIServer -Server $FQDM -Confirm:$false
Not sure what you are trying to accomplish, but as someone who works with products that integrate with VCenter, having a cert update that frequently would cause us major issues. If you can’t leave the default one on, then you should just use an internal CA to generate a cert for it.
So, the goal is to get a CA-signed certificate from Let’s Encrypt Into my vCenter server. I’m taking a wild guess that the product you work on is breaking Because the certificate is not signed by a trusted authority. My goal is to get a legitimate, trusted, signed certificate into the vCenter.
I’m with @AaronK , use your internal CA to generate a valid certificate for your vCenter. The root from the CA should be pushed to all corporate devices as a trusted issuer anyway, so it is much easier that way and you can issue a long life certificate and not have to worry about it for a couple of years.
No, the product I work with imports the cert with the proper signature. Each time the cert changes (ie cert renewal, new cert, etc), the integration breaks. Since Let’s Encrypt will renew certs every 30 days or so, this would break the integration. It would be best to just use your internal CA for this. There’s no need for a publicly signed cert to be installed on Vcenter.
I will echo what others said, if you really want to use a custom TLS then you should utilize your own CA.
However, if you’re set on using an ACME service then I probably wouldn’t use Powershell. You’ll want to utilize the cert manager built in to vCenter and configure a custom issuer that will handle the cert request/retrieval. VMware actually has documentation on this here - cert-manager packaged by VMware - Generate TLS certificates using ACME Issuers
I hope this doesn’t need to be said, but for the love of god, do not expose any of your vCenter instances to the WAN.
It’s been a long time since I’ve picked up this project, but I finally completed it.
I’ve had no issues with changing the certificate on live production machines. It will reboot after the certificate has been installed.
This is still beta software, so please use it at your best discretion…
#------CTW_vSphere_PowerShell_API---------------#
#------Author: Taylor D. Marchetta--------------#
#------Version 1.0.0----------------------------#
param($result)
# Variables to be set before invoking the script
$CertDir = "C:\CTW\Certs\" # C:\somefolder\
$Server = "https://sub.domain.com"
$Cred = New-Object System.Management.Automation.PSCredential("administrator@vsphere.local", (ConvertTo-SecureString "MyPassword" -AsPlainText -Force))
# Ignore SSL errors for these API requests
Add-Type @"
using System.Net;
using System.Security.Cryptography.X509Certificates;
public class TrustAllCertsPolicy : ICertificatePolicy {
    public bool CheckValidationResult(
        ServicePoint srvPoint, X509Certificate certificate,
        WebRequest request, int certificateProblem) {
        return true; // Trust all certificates
# Set the custom certificate policy
[System.Net.ServicePointManager]::CertificatePolicy = New-Object TrustAllCertsPolicy
# Set the security protocol to include TLS 1.2 and TLS 1.3
[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12 -bor [Net.SecurityProtocolType]::Tls13
# Get the session ID
Write-Output "Getting session ID..."
$sessionResponse = Invoke-RestMethod -Uri "$Server/rest/com/vmware/cis/session" -Method Post -Headers @{
    "Content-Type" = "application/json"
    "Accept" = "application/json"
    "vmware-use-header-authn" = "test"
    "vmware-api-session-id" = "null"
} -Credential $Cred
$SessionID = $sessionResponse.value
Write-Output "Session ID: $SessionID"
# Format the certificate and private key files to escape newline characters
$PrivKey = (Get-Content -Path "$CertDir\privkey.pem" -Raw) -replace "`r`n", "`n"
$Cert = (Get-Content -Path "$CertDir\cert.pem" -Raw) -replace "`r`n", "`n"
#$Root_cert = (Get-Content -Path "$CertDir\cachain.pem" -Raw) -replace "`r`n", "`n"
# Build the JSON request body
$RequestBody = @{
    spec = @{
        cert      = $Cert
        key       = $PrivKey
        #root_cert = $Root_cert
} | ConvertTo-Json -Compress
# Update the certificate
Write-Output "Updating certificate..."
Invoke-RestMethod -Uri "$Server/rest/vcenter/certificate-management/vcenter/tls" -Method Put -Headers @{
    "vmware-api-session-id" = $SessionID
} -Body $RequestBody
# Close the session
# Output the RequestBody to check its contents
Write-Output $RequestBody
Write-Output "Closing session..."
Invoke-RestMethod -Uri "$Server/rest/com/vmware/cis/session" -Method Delete -Headers @{
Write-Output "Certificate update completed!"
