Leo: Regarding the viewer comment about the Wize scale. All you need to do to test the accuracy of the scale is to just take a scale you think is accurate and place them side by side. Then, every day get on both scales. If the reading are the same or within .1(+/-) of each other after a weeks use then I wound say it is accurate. That’s a better test. Also I personally would think that after getting on the scale 2x in a row I would want the weight to be the same. If my weight bounced around all over the place then I would be concerned about the accuracy of the scale.
To test the accuracy of the scale, just get a few 20lb plates and stack them on the scale every morning. Test it four-five times a week, adding more every few weeks. When you get tired of the 20lb plates, switch to 50lb plates. Actually, maybe you don’t even need the scale.
I’m not even going to make a joke about the new diet where you eat 20lbs of food off a plate! ![]()
