Hello I use Itunes to download and listen to podcasts. I can’t get either the 8th or the 9th shows of the Tech Guy even when I go directly into the Itunes store. This Week in Tech downloaded ok. Any ideas? Is it just me? Love the show and not sure what’s wrong. And Leo, I actually still use an Ipod Classic to listen to you.
Thanks so much for all you do, long time listener.
I recall @Leo saying something about them changing a server and if you have problems to go to the website and resubscribe.
Ah, I will try that. Although you would think through Itunes I wouldn’t have to do that. I’ll give it a try though. Thanks so much!
