It amuses me that Steve suggests that people using no password manager are all using weak passwords because although you’re using a password manager to generate strong passwords; you’re probably using an easily memorable master password, As for email-only login, it’ll probably mean social engineering attacks increase
I suppose that, even if you’re using your own domain, a site could check the MX record, which would tell it if you’re using a forwarding service.
As for maximum password length, and you can correct me if I’m wrong, but SHA1 produces a 38-character string and I’m not sure of the bit length but wouldn’t that mean that, over a certain length, hash collisions become more likely?
If I understand your thinking, it’s wrong. A hash always produce the same length output, no matter the amount of input. The password length won’t make a collision any more likely… for the size of the hash, say 256 bits for SHA256, then the chance of a collision is ALWAYS 1:2^256 for every possible string.
