Need help finding an app
So I need an android gps tracking app that will not only track me on a map while I am driving but will break it down into text similar to what google maps timeline does but need a better UI. Any ideas?
I don’t know if you’ll find one with maps. I wonder if you can run two apps at once and have them share the GPS data. If that is the case, then you could use a GPS Logger to get the traces and use a GPS navigation apps for maps.
I have used this app for offline navigation in a car:
I searched for GPS Logger, but have never used either of these:
