Give me a mouse everytime. I have a mouse for every computer or laptop I own. It is so annoying to use a touchpad or those older eraserhead controller (they used to be on all laptops - I only see them on Thinkpads now).
Takes me 2x as long to do anything on a computer without a mouse.
I hate touchpads. they’re a pain in the butt when I’m typing. Keep tapping or clicking accidentally. Had to go into the bios of my laptop and disable it. Strongly prefer using mice.
I prefer mice over touchpads, but I rarely work on a laptop. The only good thing about touchpads is maybe the extra gestures you can use on a Chromebook (multiple finger swipes, etc.).
Absolutely hate touchpads. Doesn’t matter the brand of hardware. Love touchscreens, but if I’m in heavy productivity mode, my Logitech trackball is my go to. It’s great especially if you don’t have room to slide a mouse around, like a couch armrest.
I love those eraserheads on Thinkpads. In my time, we use to call it the nipple and I too don’t like a track pad but the nipple is something I can tolerate.
Touchpads are okay if just browsing or simple tasks, but I don’t find them precise enough for anything more than that, like using tools in graphics programs (though pens are the best input method for that).
When on Windows laptops, I prefer using ThinkPads since they have the nub/nubbin/TrackPoint and totally disable the touchpad. In fact, I used to buy the X series ThinkPads that didn’t even have a touchpad built in.
Yes, this. I use PC and Mac both regularly. Apple has cracked the touchpad and I use it only when I have my MacBook Pro. It is large, smooth, and has great gestures. When I use my XPS I use a Bluetooth travel mouse.
Definitely only use them when forced to. A lot of the stuff I do needs pretty precise pointer control and I find it far easier with a mouse.
Been wanting to try one of those laptops with the touchpad off to the side. Seems like it would better mimic the mouse and keyboard hand positions at least.
I had a Logitech Revue, which had a similar keyboard. Decent for lean-back experience, though I prefer traditional desktop setup. I don’t really veg out on the couch anymore.
