I fancy playing with ChromeOS Flex on an old MBA i7 (MBA 6,1). It’s listed as a tested/supported device by Google.
Created the ChromeOS recovery USB. Put it into the MBA, booted with ALT key pressed, selected ‘EFI Boot’ to boot from - and all I get is a black screen.
Any ideas? I’ve checked the USB, it’s readable, has EFI/BOOT directories and files on it.
Thanks. I’ll have a read. Mine doesn’t have the T2. I looked in recovery options, the only setting I could find was adding a password to boot from another disk, which isn’t set.
