I have a deck/outdoor living space that has some outdoor string lights and other lighting that I would like to control with a smart plug using Google Assistant What are some good products that would stand up to weather and still give good functionality? TIA
You want one of these, I think: https://store.idevicesinc.com/idevices-outdoor-switch/ (Note there are two plugs, but they work at the same time, you can’t control two different devices.)
You could always buy one of the water proof boxes that are mostly used for Halloween/Christmas lights, the WiFi signal should still get through. Gives you plenty of space for transformers etc in the box.
