The idea is a travel router acts as normal router, but can connect to a wifi connection. So the caller’s network will be protected. Yes, someone can connect to the public side, but not to the private side which the caller was worried about. Personally, I wouldn’t use the provided wifi. I would require some form of hard-wired access.
