The scene from 30:35 to 31:35 is very hilarious.
You can upgrade the Surface Pro 2 but it is not very user-friendly, You have to remove the screen and digitizer to get to the mainboard and the hard drive (M.2 SATA drive) but you will almost always crack or shatter the screen unless you are very very careful and have the right tools to remove it and even then there is still a 50/50 chance of shattering the screen. I would not recommend it and the parts are extremely expensive for them.
