TP Link Extender hand off mode
Hi in Twit land,
I have setup a tplink range extender, in a section of my house. So my new SSID is “Xxxx-EXT”.
However, I have to manually connect to it when I’m in that part of my house. Is this the normal method to connect to it ? Or can I have it setup where there is a seamless handoff ?
Does tp link range extender have handoff mode ?
Does this help?
The recommendation is to give it the same name as your main network.
How should I configure the network name on my Range Extender? - Home Network Community (tp-link.com)
thanks I will make the change tonight and see what happens
changed the SSID to match the router’s and all is now working as it should. Thanks for the tip.
