I updated to the latest version of Sisoft Sandra, I am getting an Error message that the software is old and expired and it will not go farther. My system is old about 11+ years old, I have an Z87 MB wt a i7 4770 CPU… Is my system too old for sandra?
My guess would be you’re running an older version of Windows in 32 bits? It appears the free version only supports 64bit Windows these days.
https://www.sisoftware.co.uk/download-buy/
If this is not the case, then we need more info about your error message and the version of Windows on your PC to know any better.
I am running windows 10 22H2, the error message just says that the software is old and expired.
Need to know if it’s 32 bit or 64 bit?
But in any case, if that’s all the error message you get, you’re going to need to contact them. I linked the site above, make sure that is where you got your version and that it is the current version.
I would also suggest that you pay attention to the fact that this experience is not very friendly, and that maybe that software is equally undesirable in that context. Surely there is something better for whatever you’re using it for. If you just want info about your system, maybe the built in System Information tool is adequate. Or maybe you want something like CPU-Z.
https://alternativeto.net/software/sisoftware-sandra/
Its the 64 Bit version of windows 10…
