Linking Gemini Live to CarPlay
I’m not sure if this is the best place to ask this question but, but I’m sure someone will redirect my question if it should be.
I’m a long time iPhone user, so, by default, I’ve been using CarPlay. Recently I had the opportunity to try out Android Auto for a couple of weeks and I think it suits my needs a lot more. Especially since I’m a big Gemini user. Being able to use Gemini Live on long car trips impressed me.
Rather than buying a Pixel phone (or something similar) or switching out my current aftermarket stereo for an Android head unit, just to be able to use Android Auto, Gemini suggested I try setting up what’s described below. Before I start this project, I’m looking for some feedback. Just to make sure Gemini isn’t hallucinating. —————————
[Project Name???]
Estimated Costs
1. VPS Cloud Hosting (Virtual Server)
● Estimated Cost: $6.00 to $12.00 USD/month (~$8.00 to $16.00 CAD/month)
● What to pick: Look for a Virtual Private Server (VPS) with at least 2 GB of RAM and 1–2 vCPUs.
● Top Provider Options:
○ DigitalOcean: $6/mo (1 GB RAM) or $12/mo (2 GB RAM Droplet).
○ Hetzner Cloud: ~$6.00 to $9.00/mo (€5.50–€8.00) for a CAX or CX server with 4 GB RAM (excellent value).
○ Linode (Akamai) / Vultr: ~$6.00 to $12.00/mo.
2. Domain Name (Required for secure HTTPS / SSL certificates)
● Estimated Cost: $10.00 to $15.00 CAD per year
● Provider Options: Namecheap, Cloudflare Registrar, or Porkbun.
3. API Usage (Pay-as-you-go for LibreChat queries)
● Estimated Cost: $1.00 to $4.00 CAD/month (for normal personal use across ChatGPT, Gemini, and Copilot via OpenRouter).
Step-by-Step Setup Checklist
Here is the exact roadmap to get your self-hosted AI suite up and running in the cloud:
Phase 1: Accounts & Prep
● [ ] Buy a domain name: Register a simple domain (e.g., yourname-ai.com or .ca) via Cloudflare, Namecheap, or Porkbun.
● [ ] Create a VPS Provider Account: Sign up for DigitalOcean, Hetzner, or Linode.
● [ ] Create a free Cloudflare account: Connect your domain’s DNS to Cloudflare (this handles SSL certificates and secure routing to your server for free).
● [ ] Gather API Keys:
○ OpenAI API Key (for ChatGPT models).
○ Google AI Studio API Key (for Gemini models).
○ OpenRouter API Key (for Copilot / general model fallback).
Phase 2: Deploying the Cloud Server
● [ ] Spin up a Virtual Server:
○ Choose Ubuntu 24.04 LTS as the operating system.
○ Select the 2 GB RAM instance option.
○ Choose a server location physically closest to you (e.g., Toronto/US-East for lower latency).
● [ ] Set up SSH access: Securely log into your new server terminal using ssh root@YOUR_SERVER_IP.
Phase 3: Installing Docker & Environment
● [ ] Install Docker & Docker Compose: Run standard installation commands to equip the Linux server with container support.
● [ ] Clone LibreChat: Pull the official LibreChat repository into your server:
git clone GitHub - danny-avila/LibreChat: Enhanced ChatGPT Clone: Features Agents, MCP, Skills, DeepSeek, Anthropic, AWS, OpenAI, Responses API, Azure, Groq, o1, GPT-5, Mistral, OpenRouter, Vertex AI, Gemini, Artifacts, AI model switching, message search, Code Interpreter, langchain, DALL-E-3, OpenAPI Actions, Functions, Secure Multi-User Auth, Presets, open-source for self-hosting. Active · GitHub
cd LibreChat
● [ ] Configure Environment (.env):
○ Copy .env.example to .env.
○ Paste your OpenAI, Google, and OpenRouter API keys into the corresponding key fields.
○ Set a secure JWT secret password.
Phase 4: Deploying Vaultwarden (Bitwarden) & Reverse Proxy
● [ ] Create a Unified docker-compose.yml File: Set up LibreChat, Vaultwarden, and a reverse proxy (like Nginx Proxy Manager or Caddy) inside the same environment.
● [ ] Configure Subdomains in Cloudflare DNS:
○ Create an A Record for chat.yourdomain.com pointing to your server’s IP.
○ Create an A Record for vault.yourdomain.com pointing to your server’s IP.
● [ ] Issue Free SSL Certificates (HTTPS): Enable HTTPS via Let’s Encrypt through your reverse proxy.
Phase 5: Initial Setup & CarPlay Connection
● [ ] Initialize LibreChat: Open [https://chat.yourdomain.com](https://chat.yourdomain.com), create your primary admin account, and verify that ChatGPT, Gemini, and Copilot models respond.
● [ ] Initialize Vaultwarden: Open [https://vault.yourdomain.com](https://vault.yourdomain.com), set up your Bitwarden master password, and save all your API keys into your vault.
● [ ] Configure iPhone / CarPlay:
○ Open Safari on your iPhone, visit [https://chat.yourdomain.com](https://chat.yourdomain.com).
○ Tap Share > Add to Home Screen to install LibreChat as a PWA.
○ Go into LibreChat Settings > Speech and turn on Speech-to-Text and Text-to-Speech so voice chat routes over your stereo.
If you already have Apple Car Play, can’t you use the Gemini app on the iPhone? Support was added in iOS 26.4 to allow it, ChatGPT and Claude through CarPlay. That would seem to be the easiest, and cheapest option.
I got my new company car last week and it has ChatGPT built in, if I ask the car a question that isn’t to do with the onboard navigation or opening windows, setting temperature etc. it fields the question to ChatGPT, but I don’t think I can switch it to another service. I don’t use Gemini, so I can’t test, whether Gemini has already implemented it, but that was released a couple of months back, so I am guessing that Google should have updated Gemini on iOS by now to support the voice mode in CarPlay.
To the bst of my knowledge, Google has not yet made a stand alone app to use Gemini within CarPlay. I’m not sure of any timeline for Google adding this capability.
I just asked Gemini how to do it…
Apple Shortcuts (Siri-to-Gemini Relay): If you install the Gemini app on your iPhone, you can set up an Apple Shortcut (e.g., named “Ask Gemini”). On CarPlay, saying “Hey Siri, Ask Gemini” will route your voice prompt through Siri to the Gemini app.
Thank you, I’m going to try that later on today!
After doing some more research, I figured out that Gemini was giving me instructions to create a Self-Hosted AI Workspace.
The difference? Your instructions should help me create a tool to use Gemini in conjunction with the CarPlay.
Part of the instructions I was given does that. It also works with a variety of other devices. And it can also draw from multiple AI agents. And I can start with Gemini, for example, move the conversation to another agent such as ChatGPT, and then move it back to Gemini.
Also, I gather that I’ll be using tokens to request information from each AI agent. So this will be on an “as required basis’ rather than subscribing to an agent. So I’m saving money.
At least, that’s how I understand it. It would be great if someone who is more knowledgeable on the topic can add their two cents
The instructions you posted worked just as promised. Slick solution. Thanks! Only problem is the shortcut won’t work when the phone is locked (that happens by design, I don’t think you can modify that).
Have you checked these options? Might work, it says…
Thank you all again for your input. I now have figured out how to get Gemini live working through CarPlay while I’m driving without worrying about iOS locking me out. Here is a summary of the steps I followed.
Step 1
Create a short cut to activate Gemini Live. Don’t use the word Gemini in the name of the short cut so the iPhone/Siri don’t get confused. I called my short cut Let’s Chat, for example.
Step 2
To prevent Driving Focus from automatically turning on when you connect to your car, go to Settings > Focus > Driving, tap While Driving (under Turn On Automatically), and select Manually. This keeps Driving Focus from activating on its own so it won’t interfere with keeping your screen active or launching Gemini Live.
Step 3
Adjust the Auto-Lock settings. Open the Settings app, tap on Display & Brightness, and then select Auto-Lock. From there, you can choose “Never” so the screen stays on.
The only slight hassle is that you need to remember to physically unlock your phone before you start driving and physically lock when you get out of your car. Maybe there’s an iOS shortcut for that. Who knows.
