Hello Twit community,
I need your help finding a cloning solution. I would like to create a “snapshot” backup of everything on a Dell 7420 laptop and be able to restore the snapshot to a Dell 7440.
It has nothing to do with Acronis not being able to do it. Because of different chipsets, you will need to install all the correct drivers for it to work correctly. The imaging software can’t do anything about that.
ah okay. from your experience what is the best way to the drivers of the 7440 ? is there a method to include it in the acronis restore ? or let it boot into windows and then have the drivers on a subsequent usb ? and install from there ?
If you know the final destination platform (as you seem to) then you could download the drivers you’re going to need into the system (obviously not install them) in to a “temporary” folder so they’re there when you do the installation of the image on the new platform. That way they’ll be ready and waiting, in case it’s otherwise difficult to get them downloaded (say for example because the network drivers are needed to get a network working.)
There is one issue you should be aware of before you go down this route, BTW. If your license for Windows was an OEM license (as they frequently are with DELL machines) then you may not be able to activate your new machine without purchasing a new Windows license. If both machines came with one, you should be okay though, but you’ll need to input the correct Windows key into the machine to get it to activate.
