Once again, to prevent any surprise, this is a truncated video. To see the full video content you need to watch it as a Club TWiT member.
such a BEAUTIFUL video by Mr. Nielsen ((chef’s kiss))
I still can’t get my head around what prescription I’d need to use VR. Is it a single prescription for displays a few inches away, or your normal ‘real-world’ prescription? In my case, that would be progressives with three different prescriptions per eye.
The same here, I have varifocals, I need different correction for near, middle and far. I also have a difference between the correction in the two eyes that exceeds the maximum that you can correct, so I always have to have one eye a bit out of focus, otherwise the brain can’t cope with the big difference and can cause depth perception problems, dizziness and nausea…
Took a look at the Zeiss ordering instructions, they use near and distance prescriptions only.
My brother has a Meta Quest, which you can wear with glasses I think. Must give it a go.
A friend has one and says it doesn’t work with varifocals.
