I have a Hisense 49" Class 4K Ultra HD (2160p) HDR Smart LED TV (49H6E), and a Google Assistant house. The TV can use Alexa to control. Is there any way on the back end to make my google home talk to Alexa to control my TV? Ideally, I am ok with just to be able to turn the tv off and on. Changing the volume, change the input, and change settings are not really need. I all ready am using Mi box for my main entertainment box.
Well it’s not the cheapest solution, but it might be the best choice: Turn off whatever is built into your TV and make it as dumb as you can. Then get a Logitech Harmony setup, which Google works very well with “OK G, turn on the TV.” “OK G, tune the TV to channel 1234.” “OK G, turn up the volume on the TV.” etc
