Is it possible to revert back to MacOS on a Mac after one has installed Chrome Flex on it? Any suggestions or advice is greatly appreciated.
You can download macos and install it from usb in the same way that you would have installed chrome flex.
Just Google install macos from usb, there are lots of guides.
Though I appreciate you responding, I was looking for a little more than, “google it”.
Is there anyone that has real world experience doing this and, if so, was there any issues?
I took it that since you’d managed to install flex then your comfortable with tasks like this. It’s a regular thing that people do and anyone who has replaced a hard drive on a Mac or had to reinstall macos for any reason has likely done it this way.
The fact that your installing over the top of another OS doesn’t really matter. Your chrome flex will just get wiped as part of the process. Ultimately you’re installing macos on a Mac, you’re not doing anything out of the ordinary.
